Melted #4 piston
Kpro22
73
Jul 15, 2016
San Diego, California
After doing a compression test 60-120-155-155 , I took out the head and found this on piston #4. It’s looks like it’s been melted. Does the block needs a new rebuild?
I would say that it was a lean condition, if it was timing they all would exhibit similar damage, probably either an air leak, or an injector seal leaking or an injector or driver not allowing enough fuel flow in that cylinder, have that injector cleaned and flow tested before even thinking of putting it back into service.
  • Wanted 6 bolt NT water pipe
    • chrisman287
