MBC problem
Fern-tsi
72
Feb 5, 2009
Lakeland, Florida
Im running a Tial 38mm WG with a 10pnd spring. The problem is that if turn (tighten) my mbc all the way in i'm in the 25 ish psi , which is fine. But if i open the mbc just one click it only boost's up to 10 psi.
I don't have any wiggle room at all.
By the way its an ebay ball&seat type.:ohdamn:
I really don't know what to tell you if only has clicks and no turns like a threaded one. How much did you pay for it? Why don't you make your own one from lowes racing engineering or home depot performance? They are cheap and reliable. It is super easy to make it. Here is some help.
It does have threads , it was about 20 bucks.
I'll try the Home Depot mod.
The way its installed as follows: boost source is driiled and tapped 1/8npt barb to the neck of the compressor housing to bottom of boost controller and top of boost controller to WG.
If that helps.
Its hard to say what quality eBay knock off's are so I would try a different controller and go from there.
Any pic's so we know what to steer clear of?
