MBC problem
gijoe985
562
20
Dec 13, 2007
Grandview, Washington
OK, I read a bunch of other threads with boost/MBC problems, but none sounded quite like mine. I've got the MBC that came with my car. Looks cheap, but I figured I'd try it out before replacing it. It is connected to the wastegate and the compressor of my t25. I was running 12+ psi on the stock setup, but with the MBC I'm either running 9-10psi, or unrestricted boost. Ig I have the MBC turned all the way to the lowest setting, I get full boost, but it seems that in any other setting I only get 10psi. I've done all my pulls in 3rd. Is the MBC just sunk? I am sure it could be, but I don't want to jump ahead without conferring...
I think that you just need a new MBC, I purchased one from ebay the pos broke when I was trying to adjust it for the first time, So I picked up a Joe P and havent had a problem.
I have the ebay 1 piece MBC, and it works great. Ive had it on my 1g ever since I got it 2 or 3 years ago. steady boosting @ 14 15 psi.
What kind on MBC do you have? post a pic.
here's a good set up the hallman you can go eather incab or under the hood. If your looking for a red one thats under the hood a Pro Kit I got a new one I'll sell you for cheap. I chnged my mind about having a red controller in my blue car. Since I just seen they started making a blue controller. Applications
