mbc need advice
exzercist
267
Feb 11, 2004
Adams, Massachusetts
i tried to hook up my mbc but it wasnt working no matter how i hooked it up or what i set it at the boost would just keep rising. the circle on the pic is where the ball and spring lay. i heard that im suppose to disconnect the tube going to the boost solinoid and not use it. i did not do this the first time. so is that what im suppose to do? well what hose do i connect the circled fitting in the pic to? does that go to the tube that goes to the intake housing. and then the other part goes to the wastegate actuator? please someone help.
the one you have circled come from the turbo, the other hooks up your actuator. If you loosen the turn knob almost all the way out, you should get the least boost. Tighten it inwards, you should get more boost. :dsm:
well i know what will make less or more boost its just that i lefted the boost sol connected and it made me over boost.
