max hp on a stock bottom end 91 6-bolt
sd1gdsm
Jun 15, 2009
san diego, California
wassup guys i just had a ? whats the max hp i can run on my 91 eclipse gsx engine.. since im upgrading turbo and gonna run more boost i wanted to see how far i can go without building my block.. 6-bolt with 95k original miles,does not burn oil,or coolant,its in reall good mechanical condition..:confused:
im upgrading turbo and gonna run more boost i wanted to see how far i can go without building my block.. :confused:
As much as it will put down before it blows. Could be 300hp or it could last till 650hp and beyond. The general consensus is that you should upgrade the pistons and rods after about 400-450hp.
This is borderline bench racing.
"There are way too many variables involved that prevent us from being able to accurately determine the data you're looking for. The members of this site strongly suggest taking it to the track or the dyno instead of having people here make random guesses."
I agree. 4G63's arent the greatest 4 cylinder engine for no reason. There almost perfect when it comes to making hp on a 4 cylinder engine.
I guess you can say no one really knows the stock bottom ends potential. Its fairly unlimited IMO, its the fact of how long can it pull that much HP.
I would like to say stock bottom ends max out around 350 hp (by that i mean they would be running at 100% work force safetly.) Anything more and your not running that bottom end safetly regardless.
I live by the rule build the car to 100% of what your want such as 500whp. And in the end make no more than 450whp. Therfore you give yourself that 10% safety net.
In the end 350 is the top the bottom end can be ran, and ran daily without many issues.
As you can see by the differing numbers being posted by everyone, no one can tell you how much whp an individual block is capable of producing/withstanding. One block may make 350whp before spinning a bearing, while another may snap a rod at 250whp. Another may hold strong until 400. Before you just go "upgrading your turbo and gonna run more boost" make sure you have ALL the supporting modifications to allow you to run your target boost. Get it professionally dyno-tuned to make the most, safest, power you can.
And don't just run your car till you blow the engine. 6-bolt blocks don't grow on trees.
Closed for now for bench racing.
