mass air flow sensor dropping circuit voltage
dfink
Jul 6, 2012
Fremont, Nebraska
New car to me 96 eagle talon and new to dsm and turbos but pretty good at older porsche so know a thing or two. Bought the car with all the good stuff I thought. FMIC, g16, boost controller, safc, walbro 255, blow off valve and a ton off messed up connections.
Working through connection and trying re-establish functionality I have found the sensor supply voltage circuit to be running at about 1V it should be 5V. If I unplug the mass air flow sensor the rest of the system goes back to 5v. I assume then that there is a problem with the the mass air flow sensor.
The numbers on the sesor are 5Y07F E5T06071 6.09 just wondering if there is a known issue with this or if it is just bad. I tried a search and really didn't find anything about the sensor pulling down the the rest of the system.
Concluded the volume air sensor must be faulty. Found a used one plugged it in and all is happy happy happy. Sensor circuit voltage at all sensors back at 5V
