MAS Differences
FyxxterZC
148
Sep 30, 2002
Morganton,
Does anybody know if the newer eclipse v6's mas will work on 1g's and 2g's? Is it mas or map? Also took a look under a co workers hood the other day (2003 grand prix) coil on plug ignition stock OMG .Is there anybody whos resourceful enough to cross use ignition components from jy parts?
Since you have a 95 your stock mas should work great. You should have no problems up to 400hp so I wouldn't worry about replacing it or even trying it. I also noticed you wondered if it would work on 1g's. On a 1g I would just go w/ a 2g mas since you can get them for so cheap now and they are easy to install, unless you want to vent the BOV to atmosphere, then go w/ the GM mas setup. I would like to know too if it would work however.
