Manual to electric mirrors
chivocrazy69
37
4
Aug 1, 2021
lynn, Massachusetts
I have a 99 eclipse spyder and i have manual mirrors how can i convert it to electric mirrors after i grab some electric mirrors off another eclipse i have the dash mirror buttons from another eclipse as well.
you might need the door harness with the wiring for them. you might already have it, you will need to check. Mitsubishi changed some of the harnesses to a unified harness what works on all models in 97or 98. if the door has a unified harness the unused connectors will be taped up.
Same with the interior harness. If you have the plugs on the harnesses, i'm pretty sure you would just need to swap mirrors, plug them in and plug the control switch in.
I will check i think mine probably has i seen sum unplugged connectors in my wiring. Thank you for replying
