river
- 282
- 0
- Jun 9, 2004
Anchorage,
Alaska
before installing my magnus intake manifold ive been reading around trying to figure out all of the problems im may encounter during installation. i have most of the boost/vaccum lines figured out. 3 of the 4 on the manifold go to a fuel pressure regulator, one to the BOV, and one is open to be used for the boost gauge. my question is about the last tapped hole on the manifold. what do i use it for?
ive read that you need to hook up a brake booster to the manifold, how do you hook it up to this manifold, and does my car have the brake booster being NON-ABS? in the writeup i read it states that you hook up the brake booster to the manifold, but that the brake booster is a 1/4 inch fitting. the holes on the manifold are 1/8 inch. do i have to tap one out, or since my car is NON-ABS will i not have to worry about the brake booster (will i not have a brake booster)?
