MAFT problem
slaminGSX
Feb 12, 2003
Iowa City, Iowa
The problem started when i got off the interstate on my way home. I took off from the stop sign as usual and my car wouldnt rev past 5000 under 3/4 to full throttle. Under 1/4 throttle it will rev up jus fine but under a load with boost it wont rev past 5 grand, it jus acts like it hit the rev limiter. I changed plugs, no difference. I took the top of my MAFT and watched the leds, when the red led comes on is when it starts to buck and stumble. So I put my stock MAS back on the car and it runs perfectly. Do ya think the problem is in the Mass Air or is it in the translator? The translator is almost a year old and i havent had any problems with it before. I checked the wiring with a volt meter and they all check out. The voltage was the same at the mass air with the GM and the stock mass air. The MAFT is also set up in blow through. All my other mods are in my profile. Any ideas will be much appreciated.
I have the same problem but this is the first time I installed the system. I returned it to stock and it works perfect deos anyone have a fix or even an idea of what is wrong.
