MAFT installed, hesitates starting.
crazykid
111
Apr 1, 2004
Sterling Heights, Michigan
I recently installed my new SB G50, FMIC, and MAFT blow setup. I havent swapped out injectors or the FP yet so im still on the stock 450s. Its seems like the car is having trouble starting on cold starts. Once I get it started its fine, and if I start it warm, its fine, but on a cold start it takes a little bit to get it going. I have all the mode switches in the 'OFF' position. 'AUX' 4 'BASE' 2. Any ideas? Normal? What is the startup enrichment mode settings for?
Did you do any free mods? There is a fuel pressure solenoid by your drivers side strut tower on the firewall. A vaccum line runs from it to the FPR you will see it. If you removed the lines from that then you will have trouble from cold starts. But it is sometimes normal. I don't think it is your MAF-T.
try using the startup enrichment it may help you, the startup enrichment richens everything up for the first few minutes of engine running, i turned my start up enrichment on ,and it starts up now without hesitation.
