maft help!
twizdt
221
Jun 19, 2008
Madison, Ohio
Heres the problem. I Installed my 3" GM Maf and maft v2.02 today that i purchased here on tuners. I put the gm maf between my bov and intake so i could vent my bov. When my car idles, its a very low idle almost wanting to stall. I can rev it and everything seems fine tilll i hit that idle again. If i rev it up high and let of gas immediately, sometimes it will stall. I have AUX on 4, base on 2, and the other 3 knobs on 0. The only wire that isnt hooked up to anything with the wiring is the green wire which came that way. also the 2 switches on the maft are off for 3" maf.
i forgot to put my mods. Stock injectors, stock t-25 turbo running at max 16 lbs. 3"exhaust (downpipe to end) no cat. pacesetter exhaust manifold.
i didnt have an idle issue when i was stock. i just installed this today and now my idle is effed.
