maft gen 2 in 1g dsm
doverdsm90
Aug 31, 2012
Garden City, Kansas
I have a 1992 eagle talon and have a maft gen2 and arm uego. All I need to know is where do I connect the wires from the uego to make it work with the maft gen2. I found several discussions but didn't see where to connect to allow the uego to work with the maft Gen 2.
The Uego has 4 wires which are in a harness on the back of the gauge. 12v Acc, ground, 5 volt, and a blue wire for data logger. I just need to know if anyone knows where you need to make your connections on the Maft Gen2 for the Uego. I am assuming that you need to connect the 5 volt wire and ground to get the Uego to work with the Maft Gen2 but I'm a little confused as to where they tie in.
Sorry about that guys, ive been working alot and didn't even think to check the manual. it has a diagram of the plug with where to connect the Wideband wires....my bad. Thanks for the help though
