Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
Is this correct?
MAFT - Turn Base CCW or turn Idle/Mid/WOT CW or set mode switch to smaller MAF size:
ECU - sees more air, adds more fuel (longer injector pulse), and lowers timing
AFR - goes down, car runs richer
MAFT - Turn Base CW or turn Idle/Mid/WOT CCW or set mode switch to larger MAF size:
ECU - sees less air, adds less fuel (shorter injector pulse), and raises timing
AFR - goes up, car runs leaner
I'm thinking about throwing my AFPR into this mix and try to get a semi-decent tune, so I just want to make sure that I have this thing figured out
