maf trouble
khill8469
Mar 28, 2004
plaistow, New Hampshire
i have a 96 eclipse spyder gs-t i got a p0100 code that is a Mass Air Flow (MAF) Circuit Malfunction. It keeps stalling out on me at an idle. I replaced the maf sensor and it still does it. I checked the voltage going to the maf is good too. I didnt see any leaks in the boot. What should i do?
Check all you connections to the as well as the intake. If it is off more then a 1/2inch the car will stall. I had the same problem on my Mx-3.
