MAF over run?
Does EVOScan graph data or just dump out #? When you over-run your MAF, the signal gets real erratic, rather than giving you a dataset with a smooth, upwards progressing curve. Did you calibrate your MAF with EVOScan? How much boost are you running on that 54 trim?
No I get a flat spot in the graph it tops out at 1,5xxhz. Why would I have to calibrate the stock MAF or MAS on evoscan? I am running 25 psi on the 54 trim.
I also found out today that I do have a boost leak. My 24yr old 1990 crushed BOV is leaking internally. So I now have to figure out what is going to be best for my set up. It worked great un-crushed with my ebay big 16g at 15 psiROFL.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
