lsd..
You have an open front LSD. edit: not LSD, just differential.
AWDs all have a viscous center LSD. Some had a rear viscous LSD as an option.
Early 2g AWD's 95-96 have an orange sticker usually on the driver's side door when you open it that says it is equipped with a Viscous LSD in the Rear. 97-99's however I don't think had these, and it was almost a standard option I believe. It is possible however that you don't have one, if you don't have a sticker, get the rear on jackstands and look it over. Their should be a plate on the Rear diff stating exactly what it is. It is also possible someone may have swapped it out or in before you may have owned the car. The only way to tell for sure is to inspect the rear.
DSM's did not come from the factory with a front LSD.
He doesn't have an AWD, so it would not matter if there is a sticker or not. Do not bother taking it up on jacks because there is no drive system in the rear that would warrant one. If you decide to get a GSX, then you'll know what to look for when you're shopping.
