low vacuum, is it normal?
DeadlyScone
587
Jul 29, 2011
Portland, Oregon
My car at idle(900rpm) has about -13psi and at OT about -11psi. I was wondering if this is normal or way off what it should be.
Thanks for the help.
That is actually exactly what mine is but I read -19 is the correct vacuum pressure for idle you may have a vacuum leak
so you are saying it should be -19? or how do(if anyone wants to chime in) you know the appropriate vacuum for your set-up and car?
It has a lot to do with idle rpm, cam setup(large cams will pull less vacuum) I'm running hks 272s at 1000rpm idle and get -13/14
i doubt it has anything but stock cams. So then i guess that means i would have to BLT and fix all if any leaks and that will tell me my base vacuum?
wow i got some new info on this after watching a tune done on a friends car, he had really low vac 9hg untill the timing/fuel trims where tuned properly then it like 18 at 800rpm
Check your mechanical timing, if you are a tooth off then it will throw a lower vaccuum as well. But check for any boost leaks before pulling off timing covers. That's most likely the issue.
i'am pretty positive that i just have a vacuum leak, which explains allot of the power loss and richness of the car. Can you buy BLT's or do you have to make them? any good places you recommend?
It's usually way cheaper to build a BLT from parts from homedepot or menards or borrow one from someone close than buying one.
I believe there is a write up on vfaq too
Deadlyscone did you find your problem? Just curious as I have the same problem and I know my mpgs are suffering
no, i'am going out today to buy the materials needed to make a boost leak tester. Wish me well, LOL.
do you have a link? I was going off this one website and video specific for dsm's
Like most people are saying. Do the boost leak test and see where your at. My vac is at
20-21hg at idle. Now i have no boost leaks on any of the piping, But maybe a little around the TB it self. So for the most part very small leaks shouldn't make a huge difference. If it does then there is a bigger problem. But most of these small problems you just have to start eliminating very thing you can to find the issue.
ok how i built my boost leak tester was to us a tire air valve and bore a hole in the ic pipe and installed valve in it permanent and all i have to do now it block turbo intake and put air pressure to the valve and listen
but you really should do a vac test because boost leak won't make low vacuum because vacuum is created behind the tb not infront
Went to home depot, Western Nevada supply, and O'Reilly Auto Parts. Spent a total of 20.18 w/ tax and got to work on my BLT(my first one). Here is a couple pic's.
I'am going today to test it, since i don't have a compressor i have to go to m moms house ROFL
i got the same exact reading on my after market boost gauge. its normal because the altitude that we live in. i didnt understand it at first either.
Ya, but it still shouldn't be that low. Plus i know i have a boost leak anyway :/
Found my boost leak(more like boost-be-gone), The top of the TB was blowing out air as fast as i could put it in ROFL. I bought a new gasket for it last night and will probably install it tonight.
