Low Compression Result in.
assa 98gsx
122
May 1, 2002
150-150-130-150 I guess the motor is a bit toasted. the 2cylinder reached the serviced limit. I added a cap full of oil and the 2cylinder pressure jumped up to 170psi. What does that mean? Gasket? Rings? And is it okay if I keep driving it or I should replace them asap? :(
it'll be fine for a while
It may make a little difference, but it's definitely not a good thing to have a variance like that in a cylinder. Having it jump like that (jumping 5% or more) means that your piston rings are causing lower compression. If I were you, I'd follow all the specifications and make sure you did everything else correctly after you do the compression test with a warm engine (Having a cold engine generally produces a lower reading). Have your throttle plate open all the way and have all of your spark plugs out and crank it until the gauge stops moving. It's around the service limit, but you'll probably be able to drive it for awhile without much issue.
I will re-do the compression test and leak down test tmr to see if anything improved. But i remember I was also doing a boost leak test and had everything unhooked untill the turbo. I know the intake side shouldn't effect the compression insdie the block, but I am just giving myself some hope.. :cry:
It suprised me so much on how a warm engine can do to the compression.
195-190-175-190 is what I got today when I warmed up the car. These numbers made me feel so much better now! LOL! Thanks for all the great help tho. Just note to myself that gotta have a warm car next time.
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
