Low BoosT?
Romogst
71
Mar 18, 2002
What's the lowest boost you guys are running on your EvoIII 16G turbo?
Originally posted by Romogst
I was asking with everything hooked up, MBC etc... just because i heard some guy saying that he can run only 20psi lowest on his EvoIII.
Then that guy is a moron and didn't setup the wastegate correctly. The lowest you could run is probably around 12-15psi, depending on car/mods.
"Some guy" is smoking rock.
Do they even make a WG actuator with a spring that high?
More than likely his wastegate was sticking closed, for whatever reason.
