loud valvetrain !!!! wat the heck?
gsxonjackstands
Mar 22, 2005
ypsilanti, Michigan
ok i just got done rebuilting my 6 bolt new bearings, balance shafts gone etc
its starts up ok just the valve trains sounds real loud
my oil pressure is good tho wat the heck is going on
Have you even read around these forums at all....
It is lifter tick. Perfectly normal.
Want to fix it, get the 3K GT big bore lifters.
yes i am aware of lifter tick ..this is way harder louder noise but if anyone has helpful suggestionns or watever let me kno
seems like some other issue but then again maybe i am wrong.
my other dsms had tick at idle but went away when u ran the revs up when i rev it up
still has the damn noise its so bad i thought my cams were gonna seize in the head
Did you touch any of the head's components since the last time it ran ok? If you emptied the lifters for cleaning lets say then you'll get a really loud clacking noise until they fill up with oil again, and it will take a good 15minutes of driving at 3Krpm until that happens. Good luck.
