Loud Rockers
98gsspy
272
Feb 27, 2006
Raleigh, North Carolina
My rockers have always made noise but after I put the turbo on my car I feel like they are louder. What causes loud rockers. And if I do replace them does anyone know if the 4g63 rockers are the same ones in the 4g64?
Lifters develop varnish over a period of time which reduces the travel of the valve inside of the lifter. This creates slack and leads to the tapping noise you have encountered.
Sometimes changing oil to Mobile 1 full synthetic with Lucas Oil Stabilizer cures the ticking. But a very inexpensive, easy, and effective way to eliminate lifter tick is add a can of “Restorer” to oil (Walmart or any auto store has it). It works every time on 4g63 engines and is the great "Wiseman Defiant blessed”! A more permanent solution would, of course, be to replace or clean them (see: http://www.vfaq.com/mods/lifters.html). But if you don’t want to deal with the time, effort, and expense of replacing or cleaning, just put a can of Restorer in. It’s so cheap you can afford to put one in after each oil change should the tick return. On my GST it lasts for 2-3 oil changes before the ticking returns. Other reported cures are adding Rislone or Sea Foam.
i thought that stuff can cause damamge to your turbo's bearings thought. I kow that lucas stuff can clog up your turbo I have had personal expereince with that stuff
