Lots of smoke coming from under the Manifold(when using Seafoam)
TooFastTooG
521
6
May 12, 2004
Plainfield, Illinois
So today I finally tried out seafoam, which ended up working really well. My question is that I know smoke will come out of the engine if there is any kind of crack or leak, and I had a hell of a lot of smoke coming from underneath the exhaust manifold, not any from the top. I just recently got my GSX so I'm still learning, so would this mean my exhaust manifold is cracked somewhere? Or something to do with the turbo? Thanks for the help in advance. :dsm:
So this would be the gasket that connects the manifold to the turbo? And would that hurt performance at all?
Not really. If the crack is a good enough size, it will cause a ticking sound from the exhaust sneaking out the crack, and could have a slower spool time, but honestly you woudn't even notice it in the spool time.
hmmm... mine did that too.
just bad gasket.
if there is a crack in the manifold, you would see smoke coming out through the hole.
