Lots of dtc's and the car doesnt run right
Scott_S
182
4
Feb 17, 2006
Austin, Minnesota
The exact codes are p0170(fuel trim bank 1) , p0141(O2 sensor heater circit), p0110(intake air temp circuit), p0100(volume air flow meter malfunction), p0105(map sensor circuit). I know the cause of some of the codes like the p0100 I forgot to put in the mas and the p0105 the map got unplugged and the p0141 there isnt a cat but the others are leaving me clueless. You guys have any ideas what causes the others?
its saying your fuel trim is out of whack, probably because your maf is not working properly and will probably need replacing. Make sure verything is plugged in then erase the codes and see what ones pop up again because if the the maf was unplugged then tat is why you got the codes but if was plugged in then probably need a new maf
Goodluck
Have fun with that... MAS are rediculously expensive... I figured that was what was wrong with mine but I was told otherwise. Good Luck..
well the mas air code and probably the intake air temp codes are from when I forgot to plug in the mass air sensor.
