Lost interior power...
Pro3racer
549
Nov 26, 2004
Stevens Pt./UW-Whitewater, Wisconsin
I was wiring up some additional fog lights yesterday, and thought the stock wiring could handle adding foglights to the driving lights wires. I added the foglights to the corner light wires, and when i flicked the controls no the steering wheel, they flashed, then went out, all of them. Problem is, that now those don't work, and niether does my horn, gauge lights, HVAC lights, blower motor controls(blower doesn't turn on), or my SAFC even. My radio however, as does my radar detector(wired into a regular fuse my my pedals). Any help on this, I need this stuff to work, especially the SAFC! Oh, my turn signals and hazard lights work as well. I checked the fuses and links under the hood, they are fine. Any body can pin point were a problem could arise?
Did you check the fuses under the dash? There in a little box on the drivers side right by the door. You probably already checked them. Sometimes you cannot tell if they are blown or not. You need to test them. I recently had five blown and I checked every one by eye. Also some of your wires could be shorted out.
Do the parking lights run on the same circuit as those lights? Also, would a missing foglight switch (upper left corner of dash) cause a problem? Why does the SAFC now not work?
I cant tell you anything of that stuff. Check all the fuses for power first. Use one of those screw driver looking things with a light bulb in it(dont know the name). Check both sides of the fuse on every fuse.
found the missing link, the tail light fuse was blown, but like you said, looked fine to my eye until i tested that thing. My SAFC still doesn't work though, i'm going to have to pull the ecu out tonight and check my wiring, maybe a solder point broke.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
