Loose timing belt after sitting
cj8990
97
Mar 20, 2010
Chicago, Illinois
My cars been sitting for a while now and I went to replace the valve cover gasket and noticed that my timing belt was pretty loose. Have not done any work on the head so could just sitting there for 2 months cause it to loosen up?
Thanks,
Corey
It is 100% normal. The cams will try to find a relaxed position and cause the timing belt to loosen up between the gears. If your really concerned about it, check the timing marks and give it a good crank. I think you'll find the belt tension is much more reasonable afterwards. :thumb:
