Looking for some info on a PTE turbo
90AWDTalon
877
3
Jan 5, 2003
Everett, Washington
My neice's boyfriend just bought a '93 awd talon that have been quite substantially modded.
It has a pte GT3584RLE turbo, I searched around and cant find this turbo anywhere. The recipt that came with the car said it was bought at extreme psi and supports 640hp. Its internally gated with a to4e cover and bolt on pte housing.
Anyone know any thing about this turbo? Is it a GT35R variant?
I don't think that such a turbo exists. Are you sure it doesn't say GT3582RLE?
Too be honest its not a varient it is a gt35r with the smaller E cover and precisions Mitsu bolt in housing. Not trying to be pickey just wanted the correct info out there.
Later gents :)
Bryan
I think he is having compressor surge issues. I havn't been in the car but from the descriptions I'm sure its surge.
Does anyone know if we can swap out the small to4e comp housing for the one that is suppossed to come with this turbo?
What is he using to tune the car? Anyway we could see a datalog?
If you are surging, consider switching to the "s" cover with antisurge ports. Oldman had an E cover on his GT12 and it surged like crazy. After he got his antisurge S cover it cured it right away.
All the pictures I've seen of other gt35r's came with a housing similar to my holset. Is the S with ports a better option? Also do these bolt right on or do they need to modified?
The car has a maft, and is chipped, I don't know what is on the chip. I want to pull in out and put it in my reader to see what is on it. The palm that came with the car isn't working. He is buying a new one. Mine is too old to plug into his cable and it is too much of a pain in the ass to remove my cable.
They probably wouldn't fit because of turbo to block clearance. You may be able to get the current cover modifed, give some turbo shops a call and see what they say.
I was just looking at slowboy racing's website, the pte gt35r they sell has both the t04s and the 4" port shroud covers as options. I wonder if the water pipe just needs to be dented or if they are even bigger than that? I'll have to see if I can find some pics in the gallery.
