420A Looking for full gasket set
Drayton07
Oct 25, 2024
Northport, Alabama
Looking for a complete engine overhaul gasket set for 420a motor from my 99 eclipse rs. All Bottom and top end gaskets as well as accessories. Thermostat housing, throttle body, EGR.
Rockauto probably has what you need, you can select the vehicle by make, year, then engine, so Mitsu, ‘99, then 2L I4. Then the Engine section, then Engine Full Gasket Set, that might be most of what you need although i don’t know if that includes gaskets for the thermo or the waterpump, they package the lower and upper portions into 1 but list them as well so that you can check the whats included and crossreference partnumbers, then read the description to see what they contain. When i had my headgasket changed i went for Mahle Clevite, the headgasket should be Mutli-Layer Steel. Incase you’re unsure you could also search with the Dodge Avenger 1995-1999 2L I4, its the same 420a Engine as the 2G Eclipse Talon, sometimes you get more results searching that way, just make sure the partnumber is the same as it would be for the Eclipse to avoid getting incompatible parts.
