Look At This Head Gasket
DSM_ThuNDeR
565
4
Feb 28, 2008
Salinas, California
Ok guys.. I know the OEM hg is good and a mls is EVEN better, but I wanted to know if this graphite head gasket is pretty good. Its off an ebay aution... I ordered the head gasket set because I wanted the valve cover, and stem seals, camshafts gaskets.. ect. But I wanted to know if you think this HG would be fine for 20 psi(later on), I Also have purchased apr head studs. This hg has like Stainless steel rings (around the cyl walls) which should help seal things up instead of tearing through the gasket while under boost.. what do you guys think:
How the set and HG looks
I wouldn't use it for personal peace of mind, appears to be on par with OEM stuff though so I'm not sure...
ok guys today I went to a mitsu dealer and got myself the OEM HG.... and to be honest I think the other gasket might be a little more stronger... the bottom of the gasket(cylinder rings) Join from one side to the other.. plus the rings seem to have a little more ss extra meat in them.. Im not going to try it.. but I seriously would recomend it... this gasket set cost me 79.00 so the ordinary head gasket set usually cost like 40 on ebay.. and is a total scam.. thats why I went ahead and purchased the set... hopefully someone in the near future tries them out and lets us know how they worked with apr's
