For Sale Longest list of DSM Parts in history of DSM Parts lists :)
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
The Short List -
1998 Split Thrust Long Block - Refreshed 1250
Spoolin Up coil on plug for 2g DSM 330
Injen Intake pipe 80
PTE 6870 T4 Combo 3000
90 popup headlight switch 10
2g AWD manual starter plate 20
Oem Harmonic dampner 50
JMFab Twin Scroll T4 PTE 6466 Gen2 Combo 3100
Forced Four 100.1 Shift Box 240
PTE 6870 T4 Twin Scroll Kit with Mani Gates and more! 3000
Stoutly Built 6 Bolt Shortblock - Manley/Wiseco/Kiggly 3000
Built 1g Head - Supported 812 AWHP 850
Aeromotive Pro Series Adjustable Fuel Pressure Regulator 300
Waterman Mechanical Drive Fuel Pump 500
Magnus Mechanical Fuel Pump Bracket - For DSM 600
2g Ksport Coilovers 625
Driveshaft Shop 2g Level 5 Rear Axles 1400
Carbonetics 2g Carbon Fiber Doors w/ Power Windows 1300
Magnus/PAR Dogbox 97-99 Ratio w/ 6 bolt awd QM Clutch w/ 1" hubs 6300
Very Clean 1995 Mitsubishi Eclipse GST (AWD Converted) 3000
Skunk 2 pnp Coil on Plug for evo 8/9 265
Built 6 bolt shortblock 1650
Powdercoated Cherry Red "Hyundai" badged 4g63 DSM Valve Cover 125
EVO - Passenger side inner axle 40
EVO - Driver side inner axle 40
Freshly Built EVO 8 5 Speed Transmission 2200
EVO Lower Control Arm - Passenger Side Front 50
EVO Control Arm - Driver Side Front 50
EVO Steering Wheel - No airbag 125
Darkfab Twin Scroll T4 Exhaust Manifold with freshly rebuilt PTE 6765 Turbo for EVO 8/9 1600
Tein Lowering Springs - Evo 125
Red Perrin Crank Pulley - EVO 50
Red Perrin Fuel Rail - EVO 100
EVO 8/9 Sweitzer SMIM with Boomba 75mm Throttle Body 775
EVO 9 10 Spoke wheels with good tires 850
HKS 264/272 Cams 400
FP1 Cams 385
FIC 750cc Injectors 165
1993 Eagle Talon TSI AWD - 5 Speed 3800
1995 Mitsubishi Eclipse GSX - Automatic AWD 3850
Taboo Speedshop Extended Slave rod for DSM 15
EVO 8 ECU 225
Ported Garrett T28 Turbocharger 400
Lightly used Greddy Kevlar timing belt 55
TurboXS Boost Controller 45
Autometer 5” Tach with shift light 45
Blitz Full Auto Turbo Timer with 1g pnp harness 35
Vibrant Racing Vacuum block 20
Brand new Dejon Tool Non recirc intake pipe 155
1g dsm Speed Density Harness 50
Avid Racing Tuner Series 1g dsm Engine Mounts 225
Fuel Lab AFPR 125
PTE Low-z 1600cc Fuel Injectors 265
EVO Front and Rear brakes with adapters for 2g DSM 675
Fuel Lab AFPR - Purple 130
PTE 1000cc Injectors 225
VTEC This Spark plug cover 50
2g D2 Coilovers 675
JMFab Top Mount Twin Scroll T4 Exhaust manifold 950
PTE 6466 Gen-2 DBB T4 Turbocharger 1750
Kinectic/SBR 2g "short route" FMIC Core 350
Brand new Tial 38mm MVS Wastegate - Purple 235
Brand New in box Tial 50mm BOV (Purple) 220
4 bolt manual rear diff w/ axles and cups 325
Cleaned and tested 880 CC PTE Injectors 185
HKS EVC EZ2 Boost Controller 225
AEM 50 PSI Boost Gauge 125
JMFab "Race" Sheet Metal Intake Manifold - for 1g head 400
FP3 Cams - DSM 400
Built 6 bolt shortblock - Eagle Rods Wiseco Pistons 1800
1995 Eagle Talon TSI Automatic 3800
Throttle Body FIAV Block-Off plate 20
2g Manual Speed Sensor 35
2g Auto Speed Sensor 30
Old school turbonetics wastegate 40
Genuine Greddy Type RS Bov 90
Braille Small Battery tray 65
Innovative Digital Boost Gauge 100
Air horn kit! 50
Dejon 3” intake pipe 85
Black top 1g CAS 85
7 bolt forward facing oil filter housing 50
1990 style bolt oil filter housing 45
6 bolt oil filter housing 40
6 bolt oil pan 50
J pipe for 14b 16g turbos 20
Refreshed Holset Super HX40 with Billet Wheel 775
Refreshed FP Super 99 in T3 .85 Housing! 1050
2g GST Fuel Sender 40
Shurflo Methanol Pump 40
Gold Spark Plug Cover 20
EVO 8 \ 9 Aluminum Underdrive Crank Pulley 40
MSD Digital Window Switch 65
Greddy Turbo Timer 25
HKS Turbo Timer 35
TurboXS Quad Stage Boost Controller 150
2G TCU 50
2G Exhaust Manifold 50
EVO Spark Plug Cover 25
OEM DSM Spark Plug Cover 35
EVO 8 / 9 Exhaust Manifold 75
Onsoku DSM Cam Gears 85
DsmChips 2g Eprom 40
1991-1994 cluster 45
2g dejon tool long route upper intercooler pipe 100
2g black airbag 75
Evo 8 steering wheel has wear on top 200
Evo 8 front floor mats 65
Front passenger side fender evo 8 9 150
83k mile 1990 DSM Cluster 100
EVO 5 speed shifter base and cables 150
EVO 8 / 9 Carbon fiber dash inlay 125
2g megan racing shifter with base 100
2g shifter and shift cables 125
2g awd rear trailing arms with red urethane bushing 65
Oem evo 8 rear bumper 200
Yellow evo 8 9 trunk lid with spoiler 300
Black evo 8 9 trunk lid has holes for spoiler 200
EVO SSL Amp and Subwoofer 200
Yellow driver side fender 200
Tial F38 2 bolt wastegate 130
Coil on Plug setup with 300m coils 225
ACT 2600 clutch cover 125
AEM 5 Bar Map Sensor 80
Healthy 2g Knock Sensor 50
EVO 8 Blue Cloth interior - Fair Shape 300
EVO 8 / 9 Dashboard w/ Passenger side airbag 150
EVO 8 / 9 Rear Axle Pair - Only 24,500 Miles 400
Evo 8 / 9 Rear Differential - only 24,500 original miles! 800
EVO 8 / 9 Cusco Rear Sway Bar (25mm) 200
EVO Brembo Brakes - Fronts and rears 525
Used Working ACD Pump 350
EVO 8 / 9 Exedy Twin Disc - Needs Rebuilt 200
EVO 8 HKS 264/272 Cams 325
EVO 8 HKS 264/264 Cams 325
Innovate LC1/LC2 Wideband Kit 130
AEM Wideband Kit 125
Brand New OEM Mitsubishi MLS Head Gasket for DSM 120
VERY LIGHTLY USED OEM "Nylon Reinforced" Timing Belt 55
Used Gates Kevlar Timing Belt "Blue" 50
2g Tokiko Blue Struts with tokiko red springs 250
2g Tokiko Illumina Adjustable Struts with Tokiko Red Springs 400
Standard 6 bolt ARP Head Studs 50
1g non abs front lines and prop valve 85
2g non abs front lines and prop valve 85
23 Spline 91-96 Manual Transfer case 150
2g FWD 5 Speed manual Transmission 350
Good used 2g 7 Bolt Longblock 850
FIC "EasyTune" Box 325
2g Manual NON LSD rear diff 200
2g Manual LSD Rear Diff 225
Oem EVO 8 Tail lights 200
Evo 8 valve cover 200
2g gauge cluster 65
ACT 2100 Pressure Plate 125
2g throttle body with sensors 65
1g throttle body with sensors 70
ECMLink v3 GM Maf wire 50
Unorthodox Racing Aluminum Crank Pulley 40
22 Spline Manual Transfer Case 150
Genuine MHI Small 16g turbo 500
Good Used Saturn Alternator 50
Blox Evo 8/9 front rollstop 50
1g Water Neck / Thermostat Housing 35
XSPower Ebay T3 Exhaust Manifold and Wastegate 40
6 bolt water pipe - heater core deleted 65
1995 Mitsubishi Eclipse GSX Roller 850
1995 Mitsubishi Eclipse GST(AWD converted) 800
EVO Roller No title LOW Miles No Rust 1800
97-99 Manual Halfshaft 75
Jay Racing 1g Alternator Relocation Kit 105
Rexspeed Carbon Fiber EVO Armrest Cover 100
6 bolt water pipe with -16an welded fitting - illusion purple 45
FIC 750cc Hi-Z Injectors 325
ID 725cc Hi-z Injectors 325
DSM 450cc Injectors 90
EVO 9 GSC S2 cams 400
Good 1995-1996 MPI relay 25
CRACKED! Valve cover with -10 an fittings 100
1g Green top CAS 35
Polished valve cover with -12 weld in vent 225
Walbro 255 fuel pump 35
Sheepy 850 HP Intercooler core 425
Dsm power transistor ptu 35
Comp Turbochargers Billet 6765 T3 Journal Bearing Turbo setup 700
Brand new BSFab 3" Vband Downpipe 450
Kiggly 6 bolt Trigger wheel set w/ Sensor 150
Kiggly 6 bolt Flexplate 100
AFCO Dual Pass aluminum Radiator 325
1g JMFab Small Battery Kit w/ Oddessey PC680 Battery 240
Fuel Lab "Prodigy" Fuel Pump 475
Precision 6766 Turbocharger - .82 AR T3 Turbocharger (Journal bearing) 885
Very low mileage Built 6 bolt short block with Manley HD Pistons/Manley Turbo Tuff combo 2400
Dynarc Fab catch can for 2g DSM - 8an Fittings 200
Black Tial MVS 38mm Vband wastegate with clamp 225
S90 70mm Throttle Body 165
S90 74mm Throttle Body 165
2g "Euro" Tail lights 325
2g DSM K-Sport Coilover Set 650
ARP 'L19' Head Studs for a 7 bolt 200
Brand New Precision 6870 .96AR Vband turbo 1900
BSFab V-Band Bottom Mount Exhaust Manifold(T4 equivalent V-band) 1000
2g LSD Rear Axles - Both Sides 250
Automatic Transfer Case - 91-96 Ratio 200
2g Automatic LSD Rear Differential 225
2g Precision Torque Converter 750
Built 2g Automatic Transmission 3750
3g - Revised "No Tick" Lifters 65
ARP 'L19' Head Studs for a 6 bolt 158
Remote Tuning - 'Advanced' ECUFlash 400
Remote Tuning 'Simple' - ECUFlash 300
Remote Tuning - 'Advanced" ECMLink 350
Remote Tuning - "Simple" ECMLink 250
Kelford 284/284 High Lift 450
Dynatek Arc-2 Ignition Amplifier 285
Sparktech Coil-on-Plug (Standard Version) 325
MagnaFuel 750 Mechanical Drive Electric Fuel pump 650
Black Magnus Fuel Rail 120
New Rix 2000cc Fuel Injectors 575
Hallman MBC 50
Blacktop CAS with Frontline Fab cover 150
EVO cluster with 24551 miles 425
Fp Exhaust Manifold with Hardware 225
Tial 50mm BOV - Gold 150
Still A ton left -- As always dont see it ASK! and be sure to checkout the site www.rixracing.com for more photos and info.
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
