autonut
- 0
- Oct 20, 2005
Harrisburg,
Pennsylvania
Does anyone know techically what the advantages are of a long intake over a shorter one with a smaller plenum?
Cooler air is densor, densor air will let the IAT sensor allow for a better timing curve and more fuel (this is where all those ebay "chips" come in that trick the iacv so the computer throws advanced timing end result is a little bit more horsepower).
1997GST said:yes, the IACV reads collant temps and is controlled by the ECU. I know that the cheap $1 worth of radioshack parts that kids spend $20 on via ebay are mainly wired for the IATs (intake air temp) sensors.
Coolant temp sensors are a bit different, those only tell the computer that the car is warmed up and is another link in the chain for the ECU going into closed loop mode. I remember older turbo kits for hondas (I think it was a name brand) that tricked the coolant temp sensor so the car would run rich to compensate for the added boost.
1997GST said:I'm sorry, I was thinking of the FITV (fast idle thermo valve). But yes, the IACV is ecu controlled.
The coolant temp sensor does have an interaction with the cars cloed loop/open loop operation.
