loking for a quick answer for rear brakes
twizdt
221
Jun 19, 2008
Madison, Ohio
Are the 10/94 vented rear rotors the same as the 11/94 vented rotors?
Do they have the same part number? They only came on the 2g's. Late 94-very early 95.
well i found a set of rear vented but they say only for 1/94-10/94 and i know a 10/94 is still a 2g
so does 11/94 have its own set of vented?
im beginning to think that mine were switched the the 10/94 because everywhere i look 11/94 is solid
Rear 2G Early AWD W/Vented Rear Rotors
(For 2G AWD cars made from 1/94 though 10/94, check your production date!)
i dont understand why they are supposed to be solid from 11/94 on but mine are vented.
there is no part number. they are on ebay. front and rear. rears are vented and say from 1/94 to 10/94
And I keep reading that the 11/94 on has solid but my 11/94 has vented.
They could have been swapped, or your car was one of the last ones to have that rear setup.
Doubt it, I've got a 1G 92 and they aren't vented. A car with a build date of 10/94 should be a 95 2G. New model years start Aug/Sep.
If you look at your rear rotor and it has vents in the center of it like your front ones, then you need the vented rotors. There's only one vented rotor design for these cars. So if they are vented rotors, then they are correct.
Do you haqppen to know the dimensions of the vented rotors? Ill just ask the seller what the dimensions of his are.
No idea, and I couldn't find them anywhere. You could measure yours still.
