Logging EUGO with dsm link question
DDM
Dec 26, 2011
palatine, Illinois
Hello. The site will not let me post in engine management section so ill ask here. I got a 92 galant vr4 with ecmlink v3. I searched for an answer for an hour and as you see from my post count i dont bug people for stupid things that can be easily found.
My question: I want to log my air/fuel with an aem wideband. I know the white wire is suppose to plug into the ecu. My question is what pin can i use? I keep looking at the gvr4 pinout and i cant seem to find a free pin. (im pretty sure its a gvr4 pinout but not 100%) I also found this:
http://www.dsmtuners.com/forums/articles-electrical-wiring/383190-1g-2g-aem-uego-wiring.html
The problem with this is that he is saying he replaces the front 02 with the aem sensor and taps into pin 4. Then use the narrowband option.
I on the other hand wended in a different bung for the sensor on the downpipe.
I think the vr4 ecu is the same as a 1g with clips being swiched around. Is This true? If it is what pin do you guys use for logging on a 1g?
Leave the front o2 alone and weld bung hole on downpipe for wideband and run the wire to the ecu and set settings accordingly to ecmlink.
I got the bung in and the sensor in and hooked up. The issue is what pin to use on the ecu? Thank you guys for the response. But if anyone has a gvr4 and is looking air/fuel with link please let me know what pin you are using. Im really stuck on this LOL.
