Logger Karman Max Hz
onekyoung
Jan 24, 2005
Omaha, Nebraska
I assume that this is a MMCD max reading issue, based on the fact that I get much higher Karman Hz readings on my SAFC II...
Is there any point in logging Karman flow since the upper threshold is 1603.95? Is there any logger that can go beyond that point, or rather is it an OBD restriction?
highest it reads is 1606.. If you have a chip from keydiver they can double that.. They take the reading and divide it in half... So if you are flowing 1500 on the logger you are actually flowing 3000
