ECMlink log results after methanol install
Sam's GSX
5+ Year Contributor
410
56
Jun 10, 2018
Hohenwald, Tennessee
First off, I would highly recommend this AEM methanol kit, its a very straight forward install, and has yielded great results.
the kit comes with 3 nozzles (250cc 500cc 1000cc)
I started off with the 500cc, i was having pretty bad knock on the first night after the install, (not more than 3 knockret, but that's way more then I'm comfortable running).
The next morning was a night and day difference (no pun intended) i messed with link a bit and it was working amazingly, 0.4 and 0.7 knockret (1 and 2 counts of knock) and the car feels about 30% faster, I'm running 20psi and starting at 8 timing going to 17.
I switched to the 1000cc nozzle to see what would happen, i didn't misfire but i got a bit more knockret (not sure how)
1.4 max and 1.1/0.7 normally.
the tune is a work in progress, any tips are welcome but i may have changed them already, the first log is 500cc and the second is 1000cc, these are street logs so for safety reasons i dont normally rev to high in third,
Quite update, did I couple more pulls and messed with timing and fuel a bit, my last pull had no knock but did how one misfire, so I'll probably go back to 500cc
Ac
Did you ever get the boost safe wire hooked up so it switches to secondary maps when the bottle runs dry? Just curious.
Glad its working out for you! I would check the logs but can't at the moment...
Actually I did, the car is completely safe when i get real low on meth (the pump still runs when low, but the safe tune is active), plus the idle switch mod was pretty easy, i didn't even have to unplug the ecu, the (yellow/red) wire was right there in front.
And no problem man.
