LOG on my GSX
MyEclipse5
2,737
Oct 2, 2002
Normal, Illinois
i know i can't tune it but tell me if this stuff is good or bad or normal.
first of all my highest knock was 36.0 that was when i was at a stop sign then i slipped the clutch out at around 2000 and then i was in first gear till about 4800 that period i had a 36 knock.
I don't knw what info you want but here is some.
Fuel Trim High - 114
Fuel Trim Mid - 108
Fuel trim Low - 97
The O2 trim jumped around so thats good.(according to the site)
Air flow highest was 1418
Air temp was average around 120-125
My air temp seems really good, the guy online said on a day of 45 degrees he was looking at 120 and here its like 80 degrees..i dunno.
How is she?
Also if you need anymore info i can give it to ya.
36 counts is bad.
do your lifters ever tick? If so replace them before you try anything else.
Is the goo in the back of your knock sensor still tough or is it all sticky and soft?
If its soft/stick/gone replace your knock sensor.
this will help alot. ;)
Is it only knocking when you are at lower engine speeds? What matters, mostly, is when the knock starts, not when it ends.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
