2G Locating 12v switched - Problem!
Kdouglas89
436
11
Jul 8, 2013
Davenport, Iowa
Hey guys, been in the process of installing an aftermarket oil pressure sensor / gauge. For my WB gauge I used my cigarette lighter location. I was going to tack it on there, but I accidently pulled the wiring apart, so now theres like 3 black and 1 blue. I have put a multimeter to each, and none are reading 12v in either key position. I have touched the thicker blue wire in radio console, and it is also not reading 12v in either key position.
I am unable to find any wire that will read 12v that is switched???
Also - I have no radio installed, so stock pigtail is in there.
Cig lighter: check the "cigar lighter" 15A fuse inside fuse box (fuse #14).
Radio: check the "radio" 10A fuse in engine compartment (fuse #12).
I feel stupid. I forgot I pulled my radio fuse a few years ago since I never used it :banghead:. I was not thinking fuse whatsoever which is odd, so thanks for guiding me in the right direction!!
  • Wanted 6 bolt NT water pipe
    • chrisman287
