Lights on the interior/cluster are a no go
joey0480
57
Jul 24, 2006
plainsboro, New Jersey
Ok, long story short.
The interior lights will not turn on at night. I can open the passenger door and the light comes on in the inside. Driver's side...it does not.
Finally went to take it out at night. The interior cluster does not light up (not the bulbs) and the interior light dimmer does not work. No lights on anything on the interior. Fuses look good. Any advice?
tail lights work fine. I guess it comes down to the driver's door light not working along with the dimmer.
I am assuming I have to figure out what is wrong with the dimmer then?
BTW...not sure if either of these play any relevance. When I got it, it has no headunit in it. Most the wires are in a harness but there are like two with nothing attached to them and I have no clue where they go.
There is a yellow wire coming out of hte fuse box under the dash...for what...I do not know.
The AC stopped working for some reason as well.
On the dimmer switch the black wire should connect to ground, the green/white to +12V (or 15A fuse is blown), and the black/yellow should have varying voltage depending on the dimmer setting. Many people incorrectly connect radios and stuff to this wire which is NOT a +12V supply wire. Dimmers often go bad and can be pricey new. If you don't mind the dash lights on full intensity you can just unplug the dimmer and ground the black/yellow.
