Leek ps fluid out high pressure line 2g
lou schmouder
271
Jun 17, 2008
dalton, Georgia
My Gsx is leaking ps fluid out the high pressure line . Took a oring out of one of the other line put in same problem?? I reLy don't wana loop it but not sure what to do.. And input would be very appreciated ...
Any not and sorry
Years ago, I had an issue sealing one of the rack lines as well. Tried 3 different racks and swapping lines, and always a leak within a week. I ended up welding the lines up and never had annother issue.
That what I thought about doing but seemed a little much to take the Power steering and everything out. But take line to be welded b4 I make a new one thanks
Yours leak from the outside or from the inside I see you of welded on the outside and the inside but my only leaks from the inside
Each combination of rack and line that I tried had a different leak point, so we ultimately welded up all potential leaks points. Anything to avoid swapping racks again, because it does really suck to install/uninstall them.
Have you tried going to the next size up o-ring and putting some teflon sealant on the treads? Might help, I just looped mine and called it a day.
Don't wana loop it enless I have to . It is leaking on hi pressure size in the middle line acts like it not tight enough . I can move it side to side and it will start leaking
