yeti-gvr4
- 422
- 2
- Dec 23, 2010
san diego,
California
I'm just trying to get a grip on what would be leaking from this side of the motor
its dripping all the oil out in a full day...
Oil, coolant? be more specific please.
That's what i thought but i couldent see any hairline cracks or anything...\
what do i have to do for those seals just remove pulley side motor mount and take off all belts and pulleys?
my friend was telling me that i had to drop the crankshaft to do the crank seal
Also i have oil from underneath the right side of the exhaust manifold and the left side, my valves may not be sealing cause 1/4 cup of oil comes out of my intercooler when i take it out so should i put in all this work for this motor or just swap it with my fresh one that has to be assembled
You still got balance shafts?: If your leaking that bad, with no b shafts then your plug is leaking. Thats a major leak if your oil is gone in one day. check your oil filter too if its loose it will spray all over from it
