Resolved Largest Radiator Fans?
ColdAudio
134
May 31, 2005
Lynbrook, New York
What is the largest fan sizes I can use in a 2 fan setup to cool my radiator, going to hook them up directly to the ignition for constant cooling... will 2 14" fans fit? Car is stock, thanks.
well i burned out the stock fan and figure this: upgrades only mean more heat, so the cooler the better!
99gst_racer said:
Just for reference, this is what our radiator looks like with (2) 12" SPAL fans on it. There's no room for 14" fans. :dsm:
HOW THE H*LL did you mount those!?!?!? I was trying to figure it out today, and I can't figure out how to mount it flush like you did..
PLEASE reply back to this, or PM me.. thanks!
I used these little black plastic nails. Well, actually they are threaded nails, so I would consider them to be screws. They run about $5 for a pack of 4. You just run them through the core of the radiator between the fins. Then there is a nut (but it looks like a washer) that you thread on the back side. Then you simply trim the access of the plastic screw (they are about 9" long), and you're done. They are the perfect mounting solution. They are cheap, easy to use, and they keep the fans snug against the radiator without causing any damage to the fans or the radiator core itself. Here's a pic of the back side and top side. :thumb:
there isn't really a need to keep them on all the time unless you're having issues with airflow with a large fmic. other then that, the airflow from the car moving should be more then enough. what some people do is set up a switch to turn their fans on and off for that extra cooling power when sitting still in traffic or at the track, etc.
great thanks! I'll go to ace today to see if I can find those clips.. do you have a close up shop of them by any chance? thanks again
im going to be sitting in traffic ALOT, thats what i get for living on long island :D
thanks for the pics! ive got a 12 and 14 on the way, will see how the fit.... can always return whats not needed
