For Sale Large list! willing to ship or FREE Delivery to shootout!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
1995-96 TRE Trans w/ Kaaz Center diff - (Dont forget you can use a 2g trans in a 1g easily but not the other way around) - $2400
Cleaned and Flow tested FIC 1120s - $255
Skunk 2 Racing Adjustable cam gears(Silver) - $130
Brand new FP Black Journal bearing (Ported) - $850
Brand new HKS Purple Timing belt - $175
Built Eagle/Wiseco 6 bolt short block - $1650
MAP H11 7 Bolt head studs - $150
ARP 7 Bolt L19 head studs - $150
Magnus 1g Race Intake manifold - $425
AFCO Scirroco style Dual pass radiator - $300
AFCO fans w/ shroud for the above radiator - $200
Jay Racing Alt relocation - $125
HKS 272s - $425
AEM Wideband - $125
AEM Tru Boost - $225
AEM EGT - $120
Like new Competition Clutch Twin Disc clutch kit 6 bolt AWD - $750
Full blown 2g dual fuel pump hanger - 10 feed -8 Return (Anodized purple) w/ 2 FSS 255 pumps - 425
Dual External Walbro 255's with bracket - $125
NRG Front Seats w/ Wedge engineering Brackets - $700
Cleaned and flowtested ID 725 Hi-Z Injectors - $350
Cleaned and flowtested ID 1000's - $425
Red Tial BOV - $180
2g Skunk2 coilovers w/ Tokiko Blue struts - $450
Brand new 2g/evo Oliver Billet "Ultralight" Rods - $725
Used DNP Style exhaust manifold (DSM Flanged) - $50
Chinese 16g in good shape - $75
2g black box ECU - $75
EVO 8 ECU - $225
BBK 62mm DSM Throttle body - $150
Accufab 75mm Throttle body (Mustang flange) - $150
3g "No Tick" Lifters - $65
Genuine Greddy type "RS" Bov - $75
ARP 6 bolt head studs - $50
ARP 7 bolt head studs - $65
Walbro 255 pump (2g) - $40
Kelford 272s - $450
63mm Non turbo Throttle body - $125
Competition Stage 3 clutch w/ 8 puck disc (Very low miles) $275
4 bolt manual rear end w/ axles and cups - $400
2g GST 5 speed Transmission - no grinds - $350
2g GST Auto Transmission - shifts as expected - $400
2g ECMLink SD harness - $50
Brand new GM IAT w/ bung and pigtail - $25
Used DNP Style(No name) DSM Flanged tubular exhaust manifold - $50
JPipes Jpipes Jpipes!- $25
Complete 2g AWD Auto swap in good shape(Includes everything to make your manual AWD an auto AWD) - $1250
Good pull stock 6 bolt head - $225
Good pull stock 7 bolt head - $225
Billet Unorthodox Racing Aluminum crank pulley - $40
Good stock 95-96 2g AWD 5 speed transmission 110K miles - $750
ACT 2600 pressure plate - $125
ACT 2100 Pressure plate - $125
good low mileage ACT 2600 clutch kit - $275
Act Streetlite 7bolt fwd flywheel - $100
Braille - Small battery tie down/tray - $85
Good 2g MAF - $25
Green powdercoated Brembo brake set w/ rotors and pads - $675
os giken DSM twin disc clutch - worked well but will need a rebuild - $450
2g LSD Manual Rear Diff - $225
2g Non LSD Auto Rear end - $200
2g 91-96 Auto Tcase - $150
22 spline manual tcase - $150
23 spline manual tcase - $150
Good manual half shafts w/ carrier - $75
Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
Cleaned and Flowtested Rc 550 injectors - $100
Cleaned and flowtested EVO 550s - $100
Recently rebuilt to stock 1g head - $300
Good Engine harnesses (1g/2g Auto and 5 speed available) - $150
EVO 8 Steering wheel - $225
Red fuel lab filter to rail kit -6an - $85
2g prothane motor mounts (Manual) - $75 (includes the mounts and inserts)
FP Intake recirc w/ couplers - $110
Uncracked valve covers - $75
2g Tokico blue suspension w/ tokiko red springs - $325
PTE 60-1 bolt on Turbo - $525
cleaned and tested RC 1000cc injectors - $250
Tial f35mm wastegate - $100
Black Tial BOV - $175
Black Tial MVS - $225
PLEASE CALL OR TXT
304-813-2405
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
