kyb gr2 install ? (rear)
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
ok i took my old ones off. and went 2 put the new ones on and they will not go on at the base. so i tock a closer look 2day and it seams like the metal ring is rusted on how would i get them off? or should i just press out the ones on the new kybs?
some pics any help on how to get these off so i can put the new ones on.
k so your tryin to take your struts off? or put them on or what seams to be the prob? if the ring is stuck on there its going to be a bi*** gettin it off but in that case did you pry it out of the old strut boot? also re- check your part numbers make sure they didn't send you the wrong ones,
ps upload a stock vs. kyb pic side by side picture
hit it with a hammer.
part # of the old, mb515703 it also has 0a30 kyb
the kyb# 341121 it also has yi03
  • Wanted 6 bolt NT water pipe
    • chrisman287
