Koni yellows awd\fwd why is their no diffrence
2gGst98
702
58
Oct 3, 2010
Concord, North Carolina
So i was going to ask if awd and fwd koni yellows are the same, but I found it. Now I have to ask why is their no diffrence. Almost all others their is a diffrence. I am ordering them this weekend but I just got to know befor I get them.
:thumb:
If I missed this answer somewhere let me know please
I'm going to go out on a limb here and suggest that since the dimensions are the same, there's no need to put a different part number on a manually adjustable shock. if it was non-adjustable, it would likely come with different valving depending on the weight of the car.
Ps. AGX's are the same way.
The bolt up the same, hell you could put FWD stock suspension on a GSX and it'll fit just fine. The car will be all wonky though because of the weight.
Wow. A lot of guesses that are wrong, but at least we ended up in the right place. For the record, the guess that they'd "bolt up different" was wrong and the idea that swapping the springs between an AWD and FWD 2G will make the car "wonky" is also wrong. In fact, for some years, the FWD had stiffer rear springs, which would help an AWD.
  • Wanted 6 bolt NT water pipe
    • chrisman287
