knocking/ckank whenever wheels are moving
happyGilmore
Jan 11, 2005
chicago, Illinois
Well we did a clutch install on our 93 tsi awd, and it was driving fine, was completely broken in (about 1000 miles) and now whenever the wheels are moving there is a extremely loud knocking/clanking coming from the front.... my searches on here came up with chances are it's the TC, correct?... im just looking for some more advice and input before it gets taken apart this weekend....anyone???.
It actually sounds like you have a bad CV joint. They usually start clanking when they are on their way out.
Hope you tourqed the flywheel bolts down correctly. Sounds like if its not the CV joints it may be your flywheel coming loose. You may want to tear that tranni out soon. Sounds like if that is the problem it is just starting, catch it if you can.
