knocking in tranny when moving please help
laserdsm
40
Aug 9, 2005
gainesville, Georgia
searched and did not find in forums. When I start moving and get up to about 10 mph my Tranny starts making a knocking sound and as I get faster the knocking gets faster.When I slow down the knocking slows down. I'm pretty sure that the noise is coming from my transmision. Thats where it sounds like it is coming from anyways. I just recently had my flywheel turned and put in a new OEM clutch kit. I need some help. Has anyone ever had this problem :barf:
Are you sure you tightened everything down right??? CV axles, control arms, flywheel bolts OMG. If it was fine before you did the clutch job and it isnt after your done then you forgot something or screwed something up. If it was me I would go through everything and make sure. Did it do it before you did the clutch job? Sam
This needs to be moved to the drivetrain section. Sounds like you got a CV joint that went bad. It would make that noise as well. Did you fill everything back up with fluid?
what I did was have a shop put my new motor in along with my new tranny. I took them my new clutch kit and told the to use the better of the two flywheel that I had. They then told me that I would have to have my flywheel turned. They are the ones that put everything together but since then i have found things that they didn't plug in and plates that cover the bell housing not bolted in and so forth. I know, the shop sucks. So now i have to go back and fix their mistakes. I should have done it my self. I put the CV axles in about two years ago and then my motor blew up so my car sat for about two years while i biult my new motor (which i did biuld my self so i know it is right) then took everything to the shop.
