knock sensor and iac question
dadsgsx
45
Apr 22, 2009
wilmington, Delaware
i have a small issue with these two items on my 97 eclipse gs spyder its the 4g64 now turbo. I'm running a 96 eprom ecu with a jet chips burned chip in it. my iac is not working i'm pretty sure it's the wiring job i did. could somebody inform me on which wire is consider #1. just need the location. if you are looking at the connector the tab on top for releasing lets call that the top for my sake. or if somebody could snap a picture of their connector for me. second is my knock sensor, i striped it down and there's a copper wire then alum colored wire. is the alum colored wire the sheilding? i was under the impression it was, but im pulling a trouble code for the knock sensor. thanks people i'm about to donkey punch this car in the ecu.
