Knock. maybe injectors leaking?
GsxEcutioner
1,549
5
Sep 3, 2007
San Bruno, California
Hey guys, I know ive been over this a million times, but I thought about this yesterday, Like I said my car knocks under boost sometimes, its hit or miss, well I notice that when i gas hard and it knocks, I run real rich or something, I get black smoke out of my exhaust(straight pipe) and right now after i let off because of knock i get fuel smell all over the cabin. Its so bad all my passengers and I get headaches. When I put the evo injectors in, I used new o-rings and seals in the head. The seals in the head werent snug though, is that normal? They kind of just sit in there. I was wondering if this would cause knock, if they were leaking? Thanks
-Shane
mods are in my profile. TIA
also in my previous post, I have a vacuum problem at idle, it idles funny and its 12-15 in hg at 800-1000 rpms.....sounds like i have cams too. Also No knock in DD. only in boost.
-shane
timing is on point, i had redid timing three times, same vacuum, and BLT was already done, i am stumped. and Under boost, its smells so much it fills the whole cabin with fumes.
-shane
Question, When you put new insulators in the head, are they supposed to be loose? if not, what insulators am i supposed to be using with Evo injectors in our motors?
-shane
I did, still same problems. am i supposed to use the 1g seals and all, or the Evo ones?
-shane
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
