Knock buzzer installed and working
Caithness
342
Nov 2, 2003
Tampa, Florida
Yet another neat feature made possible by rom tuning. I found the code in an older post on the DSM-ECU list and decided to try it out. After spending way too long figuring out that the purge solenoid works off a fixed +12v and it's the ground that is switched, my friend and I mounted a buzzer alarm in the cabin and wired it to the purge solenoid output on the firewall.
Now every time I hit 10 knock or more, a buzzer beeps at me and I let off. My initial test chip that forced a 15 knock count made the alarm sound, so I put my normal chip in and pumped the boost a few pounds over what it's tuned for. I did a pull and one or two seconds into fifth gear the buzzer started going off so I let off. No more trying to watch the logger at the track or during those high speed test runs out in the boonies. :thumb:
I'm thinking of wiring a warning LED into the output too just to cover my bases if I have the stereo cranked up or I go temporarily deaf. However, you just can't beat an audible warning that you don't have to look away from the road for while WOT at high speed.
If you have MMCD, you can set it to make an audible alarm at any count of knock you want. Same for RPM or any other parameter I think.
