Sold Kiggly High Pressure Beehive Valvesprings -Titanium Retainers 4G63 DSM EVO
bastarddsm
5,774
1,703
Aug 26, 2003
Mendota, Illinois
These are the high pressure springs with the titanium retainers and the steel spring seats. These are designed to install at 1.440" @97lbs. They can withstand a cam with 0.500" lift at that point, or be shimmed up some if you need more seat pressure. Minimum height over the nose of the cam is 0.900" They were $380 new.
Used a couple of seasons on mild cams, then became backups. Cleaning out some surplus. Good used condition. I cleaned these, visually inspected them, checked them on a Rimmac spring pressure tester, lightly oiled them with WD40, and then bagged them.
They are ready to install and run. $250 shipped/paypaled.
